new grrl needs help!
Old Jul 28, 2007 | 08:57 PM
beadgrrl's Avatar
beadgrrl
Default new grrl needs help!
I hope someone here can help me out. Today when I went to start my 95 mustang, the key would not budge forward. I ran up to Autozone and picked up a new cylinder and went back to change it out, but for the old one to be released out of the steering colum the key has to be in the "run" position. So, how the heck to I get it to release if it won't turn to run? Please help.
p.s. I accidentially posted this in the new members thread...my appologies.
Old Jul 28, 2007 | 09:00 PM
l_shizzle_l's Avatar
l_shizzle_l
Default RE: new grrl needs help!
Is the steering wheel locked?
Old Jul 28, 2007 | 09:05 PM
beadgrrl's Avatar
beadgrrl
Um, yup. It goes a little each way. I even tried moving it back and forth to try and get the key to work.Just the key will not click forward or back. And I cannot move the gear selector out of park (cannot find any kind of manual release button either)
Old Jul 28, 2007 | 09:20 PM
94Blk5.0's Avatar
94Blk5.0
That happened to mine once, but it worked after I pushed the steering wheel one way or the other and turned the car at the same time.
Old Jul 28, 2007 | 11:47 PM
Xemeth's Avatar
Xemeth
Just move the steering wheel around and try turning it. Also, press the gas pedal as you're turning it too, if wiggling the steering wheel doesn't work. Sometimes the ignitions just lock up. It's stupid. But just wiggle it around and it should go.
Old Jul 29, 2007 | 12:29 AM
eaglecatcher's Avatar
eaglecatcher
mine locked up on me tonight, and I couldn't get the key out. I did the turn the enigine off and coast into the driveway thing, and when I stopped, my steering wheel was locked and the key wouldn't come out. I had to jiggle it aorund, and finally when I turned it back into the on position (with some muscle to hlp it out) it came loose. I had to hold the wheel in the center of the small area of travel it had. Apparently it was stuck up agains tthe locking mechanism, kind of like torque-lock in an auto transmission.
Old Jul 30, 2007 | 01:41 AM
redstangerman's Avatar
redstangerman
check your tilt (if applicable) center your column, not up, not down. there is a rod that runs thru the tilt area to the ign. switch.
Old Jul 30, 2007 | 01:10 PM
MUSTANG042004's Avatar
MUSTANG042004
That use too happen with me in my 93 mustang Iget home and the key wouldn't come out so I would drive it for awhile then come back and then it came out it was strange but i know how you feel.
Old Jul 30, 2007 | 07:03 PM
v6stang07's Avatar
v6stang07
push the brake and make sure ur car is in park for an auto and make sure the clutch is fully engaged if u have a manual.....n work both of them well to be sure...wiggle the steering wheel and just keep playin with it....im sure it just locked up
