M90 Intake Manafold
Old Aug 1, 2007 | 06:32 AM
HorsesAss's Avatar
HorsesAss
Default M90 Intake Manafold
If my understanding is currect the Supercoup's had a single port manifold, and the 2002 V6's have a dual Port. My question is how hard would it be to take a single portand make it into a duel port. or is this even feasible? Or does anybody make one for the V6 that will fit a Eaton M90?
Old Aug 1, 2007 | 07:22 AM
cobra232's Avatar
cobra232
Default RE: M90 Intake Manafold
supersix is making one for the eaton M112 cobra/lightning blower forsplitports
you can convert a splitport engine to singleport and run an M90 if you want but ported heads should be used along with a cam and ported blower to make good power. all in all it is not the best idea because of all the work involved but for 94-98 stangs it's a good upgrade that will make 200rwhp and 300ftlbs of torque. good enough for high 13 sec times
www.magnumpowers.com has some really high power M90 combo's for supercoupes that will work on a stang with a supercoupe style setup
Old Aug 1, 2007 | 02:00 PM
v6stang07's Avatar
v6stang07
i wouldnt change from asplit to single port....just me tho....i would just make ur own intake that the m112 would fit to....it doesnt look that hard if u have common knowledge and the time/resources....jst make sure u get a taller hood
Old Aug 1, 2007 | 05:01 PM
alexr's Avatar
alexr
a single port swap with a blower is only going to net you about 20 more hp than what you already have. its not worth the effort.
Old Aug 1, 2007 | 08:13 PM
thakodis1's Avatar
thakodis1
I have a friend with a supercoup that he is parting out and just figured I will try to get the motor and pnp the top half put in a 4.2 crank pistons rods roller rockers lifters and a cam and then swap the motor that would be worth it but that's a lot of work but to do all that work for convert back to a single port and blow it for 20 ponies imo not worth it
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
