highway problems
Old Sep 16, 2007 | 09:39 PM
94Blk5.0's Avatar
94Blk5.0
Default RE: highway problems
Does it have a tachometer? If so,what are the RPM's doing.
Fuel/Air filters? Throttle adjustment? Torque Converter issue while accelerating?
Even if you have 3 gears working, you should be abler to pull more than 60 (1:1 3rd gear ,and 2.73 or 3.08 rearend)
Edit: Can you go WOT from a stop, will it rev higher than what it would run on the highway? Will it pull good 0-45MPH?
Old Sep 16, 2007 | 09:55 PM
raz54's Avatar
raz54
These cars don't have anything that will apply the brakes other than the driver or some thing maybe pulling on a parking brake cable but the car itself can not apply the brakes. Even the cruise control just lets it coast if it' goes over the set speed.
"you wouldnt need to have the pedal all the way down to go 70mph...(to the guys who commented on the pedal). id agree with harford...i bet its the tranny."
quote by amrcnidyot
If the throttle cable is out of adjustment or the pedal is hitting some thing it very well could have to go to the floor to hit 70. Try bunching up the floor mat under the gas pedal, it'll be "floored" and you will hardly move.
musnicki
Sep 23, 2015 07:11 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
