HELP! NO SPARK
Old Oct 1, 2007 | 07:28 PM
daniel302's Avatar
daniel302
Default HELP! NO SPARK
alright, i'm new on here and really in a bind. i bought an 86 mustang V6 about a week ago with hopes of dropping a 302 or a 351 in it. anyway it's a little rougher than i thought and i just want to get rid of it. the problems: engine won't start. cranks fine, gets enough gas, but has no spark. i've already replaced the coil and the voltage regulator, checked the inertia switch and it'snot tripped,but i still cannot get any spark. i have very limited knowledge of electricals and i cannot figure out where the problem is. any help would be greatly appreciated. Thanks in advance.
Old Oct 1, 2007 | 10:04 PM
swooshonln's Avatar
swooshonln
Default RE: HELP! NO SPARK
can you tell if the plugs are firing at all? are your coil packs bad?
Old Oct 1, 2007 | 10:16 PM
daniel302's Avatar
daniel302
no, not firing at all, brand new coil and the distributor is fairly new, no corrosion or anything on the terminals. i just cannot figure out why it's not getting spark. all it has is one coil and the distributor. it has good compression i just cannot figure out why it will not get spark. is there a way that i can wire the coil hot or does it have to run through the EEC. any help is greatly appreciated.
Dathan
Oct 5, 2015 05:52 AM
dalehunter
Sep 25, 2015 10:51 AM
lmurf60
Sep 24, 2015 10:07 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Emblazoned
Sep 3, 2015 10:45 PM
