Need help with idle problem
Old Oct 17, 2007 | 07:36 AM
94_stang's Avatar
94_stang
Default Need help with idle problem
I've searched the forums and read what I found. The problem I'm having wasn't ever figured out in the posts that i read, plus they were from 2003. Since I'm kind of a newb to v6 mustangs I want to get everybody'sinputon this forum before just blindly throwing parts at the problem.
I have a 94 mustang auto trans w/ V6. When i start up the car from being cold it idle's at 2k RPM's I put it in gear and it drops to 1100 Rpms. I drive it for a few minutes to warmthecarup and then the idle will stay around 1300 to 1500 RPM's inpark or nuetral.
Another symptom of this high idle problem is that the car seems to speed up on it's own when driving at slow speeds. At higher speeds it just seems like cruise control (which the car doesn't have).
The carsRPM will hang when you are coasting along then it will all of a sudden drop 3 or 4 hundred RPM's and sound like it's dying out. Then after a few seconds it will come back up to where RPM's were before sputtering.
I have had the car tested at Advance Autoparts and no codes were showing at this time.
The check engine light is not on.
From what i have read it almost sounds likethe infamous IAC.
I'm also leaning towards the TPC sensor too.
Please let me know what you think.
Thanks!
Old Oct 17, 2007 | 10:51 AM
raz54's Avatar
raz54
Default RE: Need help with idle problem
A sticky IAC valve can do that and not throw a code. You can try to clean it but it usually doesn't work well against carbon build up.
Old Oct 17, 2007 | 02:14 PM
94_stang's Avatar
94_stang
I'm going to replace the IAC and see if that fixes the problem.
I will post what the results areonce i get the part put on.
Any additional advice is appreciated.
Thanks.
Old Oct 17, 2007 | 04:38 PM
l_shizzle_l's Avatar
l_shizzle_l
Clean your MAF and IAC. See if your throttle body is sticking if the forst 2 don't solve it.
Old Oct 19, 2007 | 11:30 AM
94_stang's Avatar
94_stang
Replacing the IAC did solve my problem.
Hope this post helps somebody else someday.
Thanks.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
