Slugish
Old Feb 24, 2005 | 04:30 PM
hawks05's Avatar
hawks05
Default Slugish
alright heres my problem right around 60-70mph at WOT the car acts like it has a lack of power but once it gets to 70 it just gets back in it again like nothing was ever wrong. The shop i used to work at the owner said it acts like it just doesnt have enough torque right there. any help?
Old Feb 24, 2005 | 04:55 PM
slegos888's Avatar
slegos888
Default RE: Slugish
do you have a 5spd or an auto.....either way the upper gears are meant to be gas saving gears so upper rpm acceleration will be slow.....
Old Feb 24, 2005 | 06:30 PM
hawks05's Avatar
hawks05
Default RE: Slugish
its an auto well im hoping with the head swap onc ei finally get it done and the cam it wont be a problem never did it till i got the comp reprogrammed
Old Feb 24, 2005 | 06:35 PM
HRnB's Avatar
HRnB
Administrator
Default RE: Slugish
I have to agree with slego on this one. 60 to 70 is a standard highway speed and V6 Stangs are econo hwy cars. When I put my 4"10's in it changed everything and now my RPM is around 2500 65 mph (if I remember correctly) and if I stomp on the gas at 65, it shoots like a bullet.
Old Feb 24, 2005 | 06:47 PM
hawks05's Avatar
hawks05
Default RE: Slugish
so will swapping on the split port setup p&p with a cam take care of that?
Old Feb 24, 2005 | 06:50 PM
slegos888's Avatar
slegos888
Default RE: Slugish
more power will help but better gearing will make the biggest difference....its hard to change gearing in the tranny but some 4.10s out back should liven it up a bit!!
Old Feb 24, 2005 | 08:27 PM
97Stallion's Avatar
97Stallion
Default RE: Slugish
definately change to a different rear-end gear and you'll be closer to you "power band" when you're at 70. Going from 4.10's to 3.27's will be a big jump. You'll be at about 2500rpms at 70mph. Compared to being at 2000 where there is almost no power.
Old Feb 24, 2005 | 10:02 PM
hawks05's Avatar
hawks05
Default RE: Slugish
4.10s huh what all will i need to install them?
Old Feb 24, 2005 | 10:32 PM
97Stallion's Avatar
97Stallion
Default RE: Slugish
you should just need the gears, but a shim kit could never hurt either.
Old Feb 25, 2005 | 12:28 AM
Chanedeezy4106's Avatar
Chanedeezy4106
Default RE: Slugish
Yea i'm thinking about going 4.10 or 3.73 in my manual v6
Nurdyguy
Mar 15, 2015 10:20 PM
BeastMachine67
Sep 1, 2012 10:07 AM
1992 5.0
Oct 16, 2007 10:20 PM
WesDe
Apr 22, 2005 03:47 PM
e40water
Mar 7, 2004 12:28 PM
