p1443 code thrown
Old Nov 7, 2007 | 04:46 PM
bat/\/\an's Avatar
bat/\/\an
Default p1443 code thrown
i got a check engine light so i went and got it read and it said it was a p1443 code. the guys said it could be and exust leak or a slow vaccum leak or a number of other things. anyone here know wats it ismore liekly to be .
Old Nov 19, 2007 | 03:29 PM
bat/\/\an's Avatar
bat/\/\an
Default RE: p1443 code thrown
so nobody knows wat it could be?
Old Nov 19, 2007 | 04:46 PM
l_shizzle_l's Avatar
l_shizzle_l
P1443 Evaporative Emission Control System--Vacuum System, Purge Control Solenoid Or Purge Control Valve Malfunction
Old Nov 19, 2007 | 04:50 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Ahh, I had that code before!
My solution: Rip the EGR out and turn it off!
Old Nov 19, 2007 | 04:57 PM
njdanmustang's Avatar
njdanmustang
Ihad it once too as well! All it turned out to be was the guy at the gas station put the cap on wrong! Try taking off and putting your gas cap back on and reset it before you start spending money.
-Dan
Old Nov 19, 2007 | 06:20 PM
bat/\/\an's Avatar
bat/\/\an
two questions wat an egr. and also how do reset it. and i drive an 96'
Old Nov 19, 2007 | 08:47 PM
jpacetti's Avatar
jpacetti
Your egr is your Exhaust Gas Recovery. The valve itself looks like a flying saucer. The solenoid is a small, around 3" x 2", rectangular box with two rubber hoses and an electrical connector. Those rubber hoses and a tube off your EGR valve both hook up to your right exhaust header. Both are mounted on the back right corner of your upper intake manifold. Try getting a can of elctric cleaner and clean the electrical connector and replace or clean the rubber tubes.
To reset your code disconnect the negative cable from your battery for about 5 minutes.
I have had this problem in the past and have replaced the fuel purge cannister solenoid. This looks like a small coke can and will be inline with some vacum lines at the back right corner of your engine compartment. These run 40 - 50 at AutoZone. I would try changing the hoses and cleaning the electrical connectors first. Also there is a small switch in that same line. It has 3 wires one is purple and white. Be careful it will fit on your A/C low pressure switch whitch has two wires one solid purple. When I bought my 96 it took me a long time and alot of wire chasing to figure out those two had been reversed by the previous owner which kept my A/C from working and a CEL, Check Engine Light.
Good luck and let us know how it turns out.
Old Nov 20, 2007 | 09:37 PM
bat/\/\an's Avatar
bat/\/\an
well my a/c doesnt work either. and i heard storys about the purple lines.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
