windstar help
Old Dec 20, 2007 | 11:38 AM
  #31
stangant's Avatar
stangant
Default RE: windstar help
also in this pic u have the bend and i think i might use this. u say under this that u have the iac.
[IMG]local://upfiles/58457/71A3001DB33D43C68760AFE8B3232B62.jpg[/IMG]
Old Dec 20, 2007 | 12:15 PM
  #32
amrcnidyot's Avatar
amrcnidyot
ORIGINAL: stangant
and what about the distributor and bolts.??
put it where the bracket on the side of the windstar is, you dont need that bracket.
ORIGINAL: stangant
Thumbnail Image
yea, you could make soemthing like that, i didnt end up using it but i could have if i hada welder at the time. i used jbweld to put that sob together and althought it held, i didnt trust it so i didnt use it. now that ive got a welder i would make one, it was easy to do. the iac would bolt that thing sticking off to the side with the 2 hoses comming from it. the hose that sticks out and goes nowhere would plug into the cai.
Old Dec 20, 2007 | 01:34 PM
  #33
stangant's Avatar
stangant
im guessing that the wires for it would have to be extended to reach
Old Dec 20, 2007 | 10:11 PM
  #34
stangant's Avatar
stangant
and i do thank you for all of ur help although i will have more qs later..
Old Dec 20, 2007 | 10:19 PM
  #35
amrcnidyot's Avatar
amrcnidyot
its not a problem and yea the wires need extended. very easy though. just snip one at a time, although im pretty sure they are all different colors so it doesnt really matter.
Old Feb 5, 2008 | 12:23 PM
  #36
stangant's Avatar
stangant
ok update time i almost have everything i need just a few more things to move the egr and rubber tubes that i will buy 2day. also i need to make the iac adaptor and radiator hose. nuthing big anymore and looking to do this swap somethime this month.
Old Feb 5, 2008 | 12:29 PM
  #37
amrcnidyot's Avatar
amrcnidyot
sounds good. with the right intake pipe you can keep the radiator hose in the same spot. this guy has recently done a bunch with the windstar.
http://3.8mustang.com/forum/showthread.php?t=216088
Old Feb 5, 2008 | 02:56 PM
  #38
stangant's Avatar
stangant
how much pressure does the egr valve have on it.
Old Feb 6, 2008 | 04:07 PM
  #39
v6stang07's Avatar
v6stang07
the egr valve doesnt have hardly any pressure......given i jst deleted mine with a home made kit but it only works off of suction created by the air flowing past the opening in the lower intake
Old Feb 6, 2008 | 10:25 PM
  #40
stangant's Avatar
stangant
thats what i thought but just thought i would check. thanks>> now do i need to get a new hood or can i do this and buy my new hood somewhere down the road. i have heard people say yes and no.
