Steering Locks while running
Old Dec 25, 2007 | 05:03 PM
daniel_shay's Avatar
daniel_shay
Default Steering Locks while running
Hi Guys,
I have 2003 Ford Mustang V6 77K miles on it. I have a pecuilar problem it first occured on thi sunday, while turning left my steering locked, like the way it happens when you turn the engine off, but the engine was still running.
The "Service Engine soon" light comes up. I restarted the car and the problem dissapeared. I had the problem again the next day and I did the same to resolve te problem .
I checked my Power steering fluid there is fluid in there but its a lil dirty. ( I can post videos if needed)
I wanted to know if any of you had a similar problem and how it was resolved.
Thanks.
Old Dec 25, 2007 | 05:04 PM
SilvrStang's Avatar
SilvrStang
Default RE: Steering Locks while running
drain the fluid and refill,try that
Old Dec 26, 2007 | 10:14 AM
l_shizzle_l's Avatar
l_shizzle_l
The pump could be shot, drain and refill then check it after a while. If it comes out dirty then i would get a new power steering pump.
Old Dec 26, 2007 | 08:47 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Does the wheel lock, or does it just become difficult to turn? If it locks then there is most likely a problem in the column. The steering wheel locking mechanism is attached to the ignition cylinder. That's why thieves have to bust the column/lock to steal cars or they won't be able to steer at all.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
MusicCity615
Sep 12, 2015 07:05 AM
Sep 8, 2015 11:50 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
