almost ruined my engine today
Old Jan 4, 2008 | 09:49 PM
cobra232's Avatar
cobra232
Default almost ruined my engine today
coming home from work about 3 miles from home on my 60 mile drive my oil filter decides to burst. not real bad but bad enough to lose 2.5 quarts by the time i got home.
i noticed a decent dent in the filter the other day when working under the car to put a few more zip ties on a few things. didn't think anything of it. well tonight i thought i toasted my engine. i could smell oil burning when i came to a stop so i nursed it home 1.25 miles after i realized it was leaking oil.
ran it up on ramps after finding nothing on top o the engine and found where the dent was was now poped outward with a split in the middle where oil has been sprayed out.
never lost oil pressure but the bottom of the car from the K-member back to the rear got a good rust proofing.
i got real lucky as it could have happened on the PA turnpike alot further from home at higher speeds and i probably would have never smelt the oil burning going 75 mph till it was too late
learned 1 thing. never use a dented oil filter and if you find a dent or cause one putting it on just scrap the filter as you may have compromised it's integrity
Old Jan 4, 2008 | 10:28 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: almost ruined my engine today
I can honestly say that through all the stuff I've destroyed, an oil filter has never been one. lol
Take pics, I gotta see it!
Old Jan 5, 2008 | 12:17 AM
l_shizzle_l's Avatar
l_shizzle_l
I would of **** myself.
A friend of mine told me that after a certin oil pressure your oil pressure gauge reads the same no matter what. He noticed this because he had a aftermarket oil pressure gauge.
Old Jan 5, 2008 | 10:20 AM
cobra232's Avatar
cobra232
ORIGINAL: RyansQuick6
too late i threw the oil filter in my wood burning stove last night. that oil sure throws heat in that stove.
i'll dig it out of the ashes and see if i can get a pic of the rupture.
Old Jan 5, 2008 | 08:26 PM
mustangman02232's Avatar
mustangman02232
ive personally never destroyed one, but, i work at jiffy lube, and some of the idiots in there, well, they have blown motors from stuff like that [8D]
Old Jan 6, 2008 | 10:36 AM
red3.8_96stang's Avatar
red3.8_96stang
Remember the oil filter is under system pressure so if a tiny split is in the casing of the filter, the whole oil sytem will become drained out under pressure from the oil pump. Good job you got on top of it.
A few months ago I also had oil changed at a supermarket & they messed up & almost blew the motor. All because of a leak at the filter. Took only about 50 miles to 1/2 drain the sump.
Steve.
Old Jan 6, 2008 | 02:55 PM
02MustangV6DD's Avatar
02MustangV6DD
ORIGINAL: cobra232
You know your a redneck when your engine is zip-tied together...... Jiffy Lube... Haha Hope their standards have improved the past couple of years. Remeber that whole thing on 20/20 where they hid the cameras and they guys just acted like they were changing it. And if they did change the oil they wouldnt do the filter.... Thats why i do mine
Nick Oliver
Oct 17, 2018 04:22 AM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Emblazoned
Sep 3, 2015 10:45 PM
