2 Codes HELP
Old Jan 14, 2008 | 10:14 PM
JDiZzLe1788's Avatar
JDiZzLe1788
Default 2 Codes HELP
03 V6 Mustang Convertible
My girlfriends mustang is having a problem:
Manufactor Controlled Vehicle Speed, Idle Control and Auxiliary Inputs
TPS/Pedal Position Sensor A Circuit High Input
When you start it, it stars a little then dies, you start it again but give it a little gas and hold it, it will stay on but run sluggish. You let go of the gas it dies.
Please Help Thanks John G
Old Jan 15, 2008 | 12:01 AM
red3.8_96stang's Avatar
red3.8_96stang
Default RE: 2 Codes HELP
Sounds like your TPS (throttle position sensor) is bad , should read about 1v or less at idle I believe. I would replace that since it is used for idle speed (infact used all through the rev range of the engine).
You can also try unplugging the IAC (Idle air control) & see if that improves the idle, if it does then the unit is defective.
If you want to read up a bit try http://www.fordfuelinjection.com/
ATB Steve
Old Jan 16, 2008 | 07:37 PM
JDiZzLe1788
i dont think i could check it since it doesnt stay on lol but can i clean them?
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
