cruise control problem
Old May 7, 2008 | 12:46 AM
nikbait's Avatar
nikbait
Default RE: cruise control problem
Yeah, I got 'em off ebay. How do I switch the buttons without busting everything. I tried the new switches, and that isnt it. The CC still isnt working. I'm thinking either a vacuum leak or something similar.
Old May 7, 2008 | 02:26 AM
JKs95stang's Avatar
JKs95stang
Just get a small screw driver and they will snap out. As for the CC not working, checking lines and such is definitely a good idea. It sounds like the new edge's have this problem, maybe somebody will chime in with the same problem and fix! I know with my 95, i have to hold down the accel button for a few seconds, but that's probably not the issue with your Cruise. GL
Old May 7, 2008 | 07:42 PM
nikbait's Avatar
nikbait
I tried that with my old buttons, and the little tabs snapped right off.
Old May 7, 2008 | 08:52 PM
JKs95stang's Avatar
JKs95stang
If I remember correctly, I stuck a little flat tip screwdriver on the left side of the button and it popped right off.
Old May 10, 2008 | 08:08 PM
nikbait's Avatar
nikbait
Apparently since my V6 is an early model 1995, the switches don't match. The seller that I bought the switches from on ebay is going to send me the correct switches. I just hope that that takes care of my problem. If not, then I think I'm not going to worry about it. Too much of a PITA.
Old May 12, 2008 | 07:49 PM
nikbait's Avatar
nikbait
Well, the new set of switches is not the problem. I dont know what else to do...
Old May 15, 2008 | 10:15 PM
nikbait's Avatar
nikbait
Turns out that a plastic piece on the cable that hooks up at the end of the cable was busted, and that's what was causing the CC to not work, found it by accident while cleaning the engine bay this afternoon. YAYAYAYY.
2007CalSpec
Dec 13, 2020 11:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
M3hunter
Sep 5, 2015 03:42 PM
