a horrible smell
Old Jan 30, 2008 | 01:01 AM
Fink's Avatar
Fink
Default RE: a horrible smell
it sure is your brakes... i replaced my rear brake pads and actually had to replace the whole drive side rear caliper... i was goin about 40 down the road to my house and wasnt payin attention and had to push the brakes a little too hard like a day after i put the pads and caliper on and when i got out of my car at home it smelt the smell you did.. kinda smells like someone has been welding around your car right?
Old Jan 30, 2008 | 07:38 AM
LilRoush's Avatar
LilRoush
ORIGINAL: pepej90
Any advice??
Don't race a car that isn't meant for racing. You won't get that smell anymore.
Old Jan 30, 2008 | 10:18 AM
1367mustang's Avatar
1367mustang
If it is a standard then you may have down shifted and the clutch is slipping. Bad smell is the result. Also per above, brakes will give a foul odour as well.
DO NOT RACE !!!!!!!!!!!!!!!!!
Regards
Brian
Old Jan 30, 2008 | 10:29 AM
njdanmustang's Avatar
njdanmustang
It may be the brakes, if it warms uproll downthe windows see if you can smell it at a traffic light. I just went through replacing a frozen brake calipar and the wheel was a mildly warmer than the others due to radiant heat.
-Dan
Old Jan 30, 2008 | 10:35 AM
The Yellow Pinto
Guest
Posts: n/a
yeah, burnt up pads have a real unique smell to them, as coolant has its unique smell to it. my guess would be the brakes, or if you are shifting hard, could be the clutch you are smelling...
Old Jan 30, 2008 | 06:13 PM
pepej90's Avatar
pepej90
Its actually an auto. So no shifting done on myy part..
And yes to the description on how its as if someone was welding around my car.
thanks guys
Old Jan 30, 2008 | 07:48 PM
The Yellow Pinto
Guest
Posts: n/a
if it is that kind of dentist office type smell, it is almost 100 percent the brakes. just replaced the pads and turned the rotors on my gfs cougar, and thats what it smelled like.
Old Jan 31, 2008 | 02:27 PM
Zach3.8L's Avatar
Zach3.8L
ORIGINAL: red3.8_96stang
ORIGINAL: pepej90
Today I was racing an Si which I was ahead by like half a car. I was going about 93mph and we were on the highway and the traffic built up so I slowed down. As soon as I slowed down I noticed a horrible burning smell (not as in tires) and I knew it was coming from the engine I just don't know what it is. This is the second time this has happened to me in the same week. Any advice??
Brakes (especially drums) take a little while to bed in. They can easily be overheated during this period. I'd suggest taking it a bit more easily for a few days, gently apply the brakes & gradually increase brakeing power over 1-2 days of driving .
Mustangs from 94 and up didn't have drum brakes...
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
GLOCKer
Sep 28, 2015 07:36 AM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
96stang3.8
Sep 10, 2015 06:42 AM
