Spark plug wire problem
Old Feb 2, 2008 | 05:51 PM
fallfast90's Avatar
fallfast90
Default Spark plug wire problem
Hey everyone, i have a problem. I just replaced my spark plug wires and when i turned on my car it ran EXTREMELY rough. I turned it off, and now it will crank over, but not stay on. I am very sure that the spark plug order is correct. Would the seating of the wires cause this? Could i have bumped something that i didn't know of, or possibly got some vacuum tubes mixed up? Thanks for the help everyone.
Old Feb 2, 2008 | 07:23 PM
ayrton02's Avatar
ayrton02
Default RE: Spark plug wire problem
double check the order (the coil pack is represented on the bottom, engine is on top). make sure the plugs are seated good on the plugs and coil pack - just to make sure, i'd take them off and put them back on until i heard/felt a firm "click." as for the vacuum tubes, you should have only had to take off the tube to the pass. side valve cover that comes from the the air inlet tube... so i don't think vacuum tubes should be a prob.
Old Feb 2, 2008 | 08:28 PM
The Yellow Pinto
Guest
Posts: n/a
nice little write up. diagram and everything.
Old Feb 2, 2008 | 10:04 PM
fallfast90's Avatar
fallfast90
ORIGINAL: ayrton02
Thanks, that is exactly what i needed!!
ShaneB26154
35
Mar 4, 2021 04:05 AM
overnight89
Aug 22, 2015 09:02 PM
Philhampton1
Aug 21, 2015 12:04 PM
microgt
Aug 20, 2015 07:12 AM
