coolant flush?
Old Apr 1, 2005 | 12:46 AM
steve_mustang89's Avatar
steve_mustang89
Default coolant flush?
just before putting my new rad in im wondering if i should do a coolant flush/how to do a cooling flush and if you have any resources as to how to do it? just wanna make sure i do this all right the first time!
Old Apr 1, 2005 | 02:22 AM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: coolant flush?
You shouldn't really have to do a coolent flush. You will need a coolent flush machine to do one and its pretty expensive machine so it would just be easier to take it to a shop if you really want it done.
Old Apr 1, 2005 | 03:52 AM
HRnB's Avatar
HRnB
Administrator
You can buy a coolant flush kit real cheap from Pep Boys (around 10 bux). But you can also do it the old fashion way. when the engine is cold, open the valve **** at the bottom of the radiator. Then take off the radiator cap and turn your heater on to high in the car. Now start the car and take your garden hose and just keep the radiator full the whole time (approx. 10 minutes) Then turn off the car and let the radiator drain all the way down. Close the valve **** and refill with coolant and water and away you go.
Old Apr 1, 2005 | 02:42 PM
fats429's Avatar
fats429
That works well the flush kit is the better way with the flush detergant but is a PITA to get all the soap out . If you live in the city they will linch you for getting collant in the storm drain ( GOD DAMN TREE HUGGING YUPPIE EPA A** H***S ) the rad shop does a great job for a low price between 30 to 50 bux
Old Apr 1, 2005 | 03:02 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: steve_mustang89
Do the flush, but WITHOUT the new radiator in place and bypassing the Heater Core, otherwise any cr8p in the motor could be pushed into the radiator or the core. Also you want to do a reverse flush, that means the water is forced through the engine in the opposite direction from which it flows. Force water into the bottom hose and out through the thermostat housing. THe kit at Pep Boys will make the reverse flush a lot easier..
Old Apr 2, 2005 | 12:57 AM
steve_mustang89
alrite thenaks for the advice everyone, i bypassed the heater core and used my garden hose to run a bunch of water through, and now the new rad is in, now i just need to get the coolant all in and ill be good
4cylinderplus2
Oct 9, 2020 07:45 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
wraith777
Sep 28, 2015 10:49 AM
MusicCity615
Sep 12, 2015 07:05 AM
