tranny help???
Old Mar 1, 2008 | 01:48 PM
v6stang07's Avatar
v6stang07
Default tranny help???
ok well i just finished my shift kit and i believe everything was installed correctly. It shifts through all the gears fine but my engine is wanting to choke out when i put it in gear and when i do actually get the car in gear i only have first and second and reverse??????
im going to check the wiring connections and the filter to make sure it didnt fall off but after that what could the problem be??? any suggestions??
Old Mar 2, 2008 | 03:20 PM
v6stang07's Avatar
v6stang07
Default RE: tranny help???
bump
Old Mar 3, 2008 | 06:20 PM
v6stang07's Avatar
v6stang07
c'mon guys any help at all???
Old Mar 3, 2008 | 08:29 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Details on said shift kit -
Old Mar 4, 2008 | 08:42 AM
v6stang07's Avatar
v6stang07
its a transgo kit..... really took my time doing the valve body but wat frommy tranny culd make my engine choke out like that????
Old Mar 10, 2008 | 12:23 AM
v6stang07's Avatar
v6stang07
ttt
Old Mar 10, 2008 | 01:31 PM
deadcarnahans's Avatar
deadcarnahans
You did not mess with the gear select position sensor did you?
Check the connector on it.
Old Mar 11, 2008 | 12:42 AM
v6stang07's Avatar
v6stang07
seeing as i dont know what that is no......im tearing it back apart tomorrow.....the first thing im gonna check is the wiring if none of them are loose or broken then im gonna take the valve body back out and check all the valves to my instructions and make sure they are all plunging correct......other than that i am stuck
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
prophotog
Sep 15, 2015 08:38 AM
jaiidutch
Sep 14, 2015 10:29 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
