Overheating problem, please help!
Old Apr 8, 2005 | 03:26 AM
justinmac86's Avatar
justinmac86
Default Overheating problem, please help!
Ok so here's the deal I have a 1996 V6 mustang. Within the last month my car started to overheat. At first I put a 160 degree thermostat in, changed the hoses, and put new coolant in. This seemed to fix the problem now it goes through a lot of coolant, but I never see any under the car. The tempature will go to the A-L on 'normal' and then will cool down after it stay there for awhile, i haven't seen it hit the red yet. If i run the heater it will put out hot air when the engine is cool but cold air when its hot, kinda wierd. The oil appears to be a normal color. If you think you know whats going on let me know any imput will help out, thanks.
[IMG]local://upfiles/15300/61B0FE5966D04853BA9E51E2D65C78B5.jpg[/IMG]
Old Apr 8, 2005 | 03:40 AM
Jugador's Avatar
Jugador
Default RE: Overheating problem, please help!
i was gonna say check the oil, but apparently its ok. nothing unusual comes out of the exhaust?
Old Apr 8, 2005 | 03:46 AM
HRnB's Avatar
HRnB
Administrator
Look under the oil cap. If it has a tan goopy residue on it, your head gaskets are blown or worse, heads are cracked. But it sounds mild right now, so if you catch it early, you can just replace the head gaskets. Look for the tan goop under the oil cap.
Old Apr 8, 2005 | 10:29 AM
softsoap's Avatar
softsoap
i got the same problem on my Celica
when i was driving long ride my motor was over heating
my motors heads was crooked
Old Apr 9, 2005 | 12:31 AM
justinmac86
I took it to the mechanic today. Its a blown intake and head gasket, 1300 bucks, that really sucks
Old Apr 9, 2005 | 01:16 AM
HRnB's Avatar
HRnB
Administrator
ORIGINAL: justinmac86
Make sure you replace them with good quality gaskets so they never give you trouble again. Look into Felpro Gaskets.
Old Apr 9, 2005 | 03:02 AM
ZachW04Stang's Avatar
ZachW04Stang
Its not really that hard to do, all you need is basic tools and a torque wrench.
Old Apr 9, 2005 | 04:40 PM
justinmac86
Hey since im going to be tearing the whole top end of the engine apart to fix the problem i was wondering is there anything i could do to my engine enternally to add a couple of horses, that wouldn't be to hard to do or cost a lot of money. Maybe cams? I don't know, if you could tell me what i should add and what it would cost I would sure appreciate it.
Old Apr 9, 2005 | 06:56 PM
sarahsmustang's Avatar
sarahsmustang
I recently replaced the heads with a set I bought off EBAY, came with gaskets, and bolts, all for $280
Took me the weekend to tear down and install. Fixed my overherating problem.
tas
mungodrums
Sep 29, 2015 09:18 PM
stangin1996gt
Sep 21, 2015 11:01 AM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
