ANOTHER ENGINE?????//
Old Apr 1, 2008 | 02:08 PM
nelson122790's Avatar
nelson122790
Default RE: ANOTHER ENGINE?????//
you might have to run the whole new wiring harness im not sure if there different but the best thing would be to put the 4.2 crank in but if your looking for good power buy the 4.3 stroker kit from supersixmotorsports.com its a little pricy but its the most efficient and you could keep the original motor to the car
Old Apr 1, 2008 | 03:07 PM
l_shizzle_l's Avatar
l_shizzle_l
Get the 4.2 shortblock, everything else from your 02 3.8 will transfer over. You also have to use your 3.8 oil pan
And i think it's the 97-01ish F150 4.2L
Old Apr 1, 2008 | 03:12 PM
03stang0802's Avatar
03stang0802
i have a 2003 guys.. just lettin you know..... and what do i have to do to put a 4.2 crank in??
Old Apr 1, 2008 | 03:19 PM
l_shizzle_l
oops my bad. It dosn't matter tho, for a 01+ it's a pretty simple swap. You have to take the engine all the way out of your car, then tear it down completely, all the way to the crank.Then you need to get the block bored/honed, then put it back together. Take it from me, it's a lot easier to just get the 4.2L shortblock.
And Ryan, where can you get block work done in 2 days? It takes weeks usually to get your stuff done at those places.
Old Apr 1, 2008 | 03:25 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Buy a built forged 4.3 from ssms/rpm
Old Apr 1, 2008 | 03:40 PM
l_shizzle_l
ORIGINAL: VCS_SSSTANG
+598230430984million093240978
03stang0802
alright thanks.. im gonna do a lil more searchin and ill probably end up gettin a 4.2 or 4.3 engine... but with either of these will i need to buy anything else? or can it go right in??
Old Apr 1, 2008 | 03:44 PM
03stang0802
ORIGINAL: l_shizzle_l
huh?! whats this mean??
Old Apr 1, 2008 | 06:07 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
I know people lol. j/j
You really can get by with just puting in new crank bearings and tossing the 4.2 crank in there. I don't believe the blockhas to be machined for the rods.
If it does has to be "clearanced" for the rods, then yes it's a full on rebuild.
He seems to have some good experienced support as well.
I've never waited weeks on anything from a machine shop, not even a rebuild. I can get a block dipped and honed in a day assembly done by the following day, a diesel block at that, and heads may take up to 3 days if they're busy. I usually just get a machine shop to clean and prep the block, install freeze plugs and cam bearings, instal valves, and assemble overhead-cam heads, the rest I do myself.
Old Apr 1, 2008 | 11:23 PM
l_shizzle_l
Do you file fit your rings? For a normal person it would take a littlebit longer.
