bleeding the rad? Helpp!
Old Apr 5, 2008 | 08:36 PM
Deepenough's Avatar
Deepenough
Default bleeding the rad? Helpp!
I was driving my car around after the windstar swap. I also took out the lower intake to port an a d polish it during the install. During this i guess an there were air when i was bubbles when i put the lower back on. Today whern i was driving my car around it was overheating like crazy. I think the reasonis because of the air bubbles inside the system. So i was wondering if anyone could tell me how to bleed the rad/cooling system that would be amazing! Also any other opinions on why it could be over heating??
Thanks again!
Old Apr 5, 2008 | 08:40 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: bleeding the rad? Helpp!
Windstar swap? Please explain. How did you go about refilling the cooling system? Exactly.
Old Apr 5, 2008 | 09:08 PM
Redneck1465's Avatar
Redneck1465
Bleed it like you would bleed the system after you do a radiator swap. Just start the car, then leave the radiator cap off and let the bubbles come out.
Old Apr 6, 2008 | 09:32 AM
The Yellow Pinto
Guest
Posts: n/a
my pickup did the same thing when there were air bubbles in the lines. bled the system, got em out, dropped back to normal temps. good luck, i betcha thats the problem.
Old Apr 6, 2008 | 10:06 AM
troy81's Avatar
troy81
ORIGINAL: Deepenough
Thanks again!
is that part english? :-p just messin
Old Apr 6, 2008 | 01:43 PM
Deepenough's Avatar
Deepenough
Oh, sorry. Haha i was typing on a really wierd keyboard. I also found out that my heat wasn't working inside the car, so i changed the thermostat.I believe it was stuck closed. Also im going bleed rad properly in just a few minutes when my gasket maker hardens up where the thermostat is. After that... i have another problem to ask you about... its relevant to an air leak in the windstarupper intake manifold. Problems just keep on coming...
SteelerNation82
Sep 16, 2015 07:11 AM
steelers743
Aug 31, 2015 07:16 AM
19tony67
Apr 9, 2005 04:51 PM
steve_mustang89
Apr 1, 2005 02:54 PM
jma91678
Jul 23, 2004 10:39 AM
