door lock issue
Old Apr 25, 2008 | 01:07 PM
wolf39us's Avatar
wolf39us
Default door lock issue
I have a new issue with my 2000 v6 mustang and the door locks..
the behavior is the same on both sides
lately when I go to unlock/lock the doors...the door locks will go halfway up and then go back down....same thing happens with locking as well
you CAN hear the relay clicking when you do this...
so far if the car is DRIVING ...the problem does not occur...
so I'm thinking there is some sort of electrical issue...maybe not enough juice going to the locks?
what do ya'll think?
Old Apr 25, 2008 | 01:12 PM
SonicBluev6Stang's Avatar
SonicBluev6Stang
Default RE: door lock issue
yea sounds like a eletrical issue,hmm do you have the engine running while its parked or just the car running on the battery when you try to use the locks/unlock?
i had a similar prob on my grand dam.
Old Apr 28, 2008 | 09:13 PM
rockstar18's Avatar
rockstar18
I have a problem like that on my 2000 v6 mustang too! on my driver side, if I try to unlock/lock with the remote, it doesn't always work, and more often than not I have to use my key. I need to get that fixed.
Old Apr 28, 2008 | 09:15 PM
skitso's Avatar
skitso
i new battery might help rockstar
and i unlock my car with the key all the time its ok
cept on dates where i have to go to drviers unlock then passengers its pretty annoying
Old Apr 30, 2008 | 08:16 AM
akp20032004's Avatar
akp20032004
You all have it easy, my power locks don't work at all and my driver's side key hole is nasty inside so my key won't work in the driver's side. So there for I have to go through the passengers side to unlock my drivers door. SO usually I don't lock my door just the passenger side.
Old Apr 30, 2008 | 09:41 AM
amrcnidyot's Avatar
amrcnidyot
ORIGINAL: akp20032004
what year car do you have?
to the op, one of the actuators could be bad, that can cause both doors to not work because the bad actuator takes a lot of power to try to work and the other door doesnt get enough because the bad one is stealing it.
Old Apr 30, 2008 | 10:46 AM
troy81's Avatar
troy81
i dont have a keyhole on my passenger side :-p but my powers work, along with my key hole
67LimeCoupe
Sep 30, 2015 04:46 PM
maestro1024
Sep 21, 2015 02:40 PM
Sep 8, 2015 11:50 AM
mustangchef
Sep 4, 2015 08:08 PM
SYNY5TER
Sep 2, 2015 01:35 AM
