got a problem
Old May 1, 2008 | 09:48 PM
skitso's Avatar
skitso
Default got a problem
i was running out my gears (racing(wellsort of)
and i went to shift to 3rd and it wouldnt go in i had my clutch in
and i wouldnt go in i tried 4 and i wouldnt either
it was so scary cause i smelt burning
Old May 2, 2008 | 01:07 AM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Default RE: got a problem
ORIGINAL: skitso
What do you mean running out your gears?
And burning is of course not a good thing.
Old May 2, 2008 | 10:25 AM
mws96's Avatar
mws96
Did you hear grinding, noises, or anything of that nature?
Old May 2, 2008 | 12:50 PM
LilRoush's Avatar
LilRoush
Smoked clutch from improper use.
Edit: By improper use I mean it was getting too hot and not engaging all the way, leading to even more heat.
Old May 2, 2008 | 03:20 PM
skitso's Avatar
skitso
letting it run till 4000rpms then shifting
umm kinda heard something but not really a grinding of gears
it wouldnt go in i never let the clutch out
so i dont know whats up
do you guys think i need a new one its still the original from factorry and its got 123000 miles on it
Old May 2, 2008 | 03:50 PM
mws96's Avatar
mws96
I would say it's about time to change it out.
Old May 2, 2008 | 05:41 PM
JKs95stang's Avatar
JKs95stang
ORIGINAL: skitso
Yup, I'd say you smoked the clutch for sure. A new clutch installed will run you about 500 bucks from a shop, or spend 150-200 on a nice clutch kit and do it yourself. GL
Old May 3, 2008 | 03:27 PM
skitso's Avatar
skitso
ORIGINAL: JKs95stang
ORIGINAL: skitso
i was told a grand or 2 to fix it
and what about snyconizers is that a possibility
any suggestions about which clutch to get
Old May 3, 2008 | 06:32 PM
moontang's Avatar
moontang
ahh the wonderful smell of burnt beans aka hotclutch FTW jj
well id say if you dont mind the weight go with a spec clutch st2 maybe? but they are a bit heavier price isnt too bad and i do believe the are tough
Old May 3, 2008 | 08:41 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Sounds like you just blew your synchros, just like everything else with a T-5!
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
