Mods Questions!
Old May 11, 2008 | 05:45 PM
RedStarBelgrade's Avatar
RedStarBelgrade
BEWARE OF THIS SELLER. He will sell you junk and call you an idiot for falling for it. Know what you are buying! Admin
Default Mods Questions!
Ok due tosome unplanned expenses I won't be able to get my Vortech installed for a while. However, I am getting SCT+ tunning. Now (a dumb question), later whenI get my s/c installed I would keep the same tuner just get it tuned again, right?...I don't know how that works! Also, what are some cheaper performance mods that would not later have to be taken off because of the s/c?
Old May 11, 2008 | 06:04 PM
The Yellow Pinto
Guest
Posts: n/a
Default RE: Mods Questions!
^^^^ 1-yes, you can use the same tuner, and just get another tune loaded. no problems. cheap mods that you wont have to get rid of when you get the s/c...get long tube headers, and a 2.5 inch exhaust. you can keep it, itll just get more efficient when you have boost! and suspension upgrades.
good luck
Old May 11, 2008 | 06:09 PM
RedStarBelgrade
ORIGINAL: songtradingusa
good luck
Oh I should've mentioned I already have MAC LTs and o/r h pipe, just got it installed couple of days ago! How about t lock, gears, throtle....?
Old May 11, 2008 | 06:41 PM
The Yellow Pinto
Guest
Posts: n/a
id hold off on the throttle body, to see where you are gonna go with your intake manifold work,s/c, etc. tranny work would be good...but if you are planning on supercharging, id go no shorter than 3.73 gears (so youll have some traction!), and go with a detroit truetrac, auburn, or eaton posi over the tlok. ive heard they break with any serious power adder.
Old May 11, 2008 | 07:39 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Either find an 8.8 or get a true trac, and gears. I just sent my 3.73s back for 4.10s so..... lowering springs, better rear tires, etc.
Old May 11, 2008 | 08:13 PM
RedStarBelgrade
ORIGINAL: VCS_SSSTANG
How to know which one is the right one, and how to make a good combo for about $500, to be ready just to install it?I tried americanmuscle but there a lot different 4.10 and I dont even know which one is good. How about this combination:
http://www.americanmuscle.com/v6gears.html
http://www.stangmods.com/V6-Mustang-...1-m4204c75.htm
Tivo304
Aug 28, 2023 12:19 PM
04stangman
Sep 17, 2015 01:45 PM
Roush05
Sep 10, 2015 12:23 PM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
