A split port swap?
How much would be the benefits (as hp gains)in doinga spilt port swap on my 98? Some other questions are how much would it cost, what parts do I need, where can I get the parts, where can I get it done, and are there any cons if I do the swap? Any information would be appreciated. thank you
Go to www.supersixmotorsports.com and look in the garage sale section. They sell the complete kit for $800. After the install and getting a tune you'll go from 130rwhp to 160rwhp.
You can buy everything youneed from CRT Racing preformance or you can get a donor motor from a 99-04 engine (cheapest way to go). Or you can buy all the pieces on ebay over time. Youll need the upper and lower intakes, new heads, new returnless fuel rails, upgade your fuel pump (I dont remember if you have to or if its just recomended), plus a new wiring harness to work with the new engine part. This is just for starters, Im sure I have forgotten alot so use the search button and it will help you find what you need.
Matthew
Matthew
Guest
Posts: n/a
you can actually learn a lot of info just by searching the old threads. youll get faster answers that way. when i first joined, i learned that time and surfing around the old threads that looked applicable to whatever ? i had was the best teacher.
as far as what an m-90 would cost, it would be whatever you found one for. search used m-90 on ebay motors, youll find some there. personally, id go with the split port swap, as youll have more options for higher hp numbers if/when you wanna upgrade (i.e. add an m112, the cobra supercharger). if you get the m-90 and want higher numbers, eh, youll probably be scrapping it for another type of blower, or the split port swap, as it is not compatible with the 99-04s.
good luck.
good luck.
