Running rough......
Ok so after I found out I had a misfire in cyl #2 ....I replaced my coil pack. That smoothed the motor out a little bit. Then just today I changed the plugs from Autolite to Bosch Platinums. That didn't smooth it out any. What else could I do and check to smooth the engine out more?
Replace your plug wires. That should help/fix it. Stay away from Bosch. Although you put new ones in there recently, I would put Autolite, Motorcraft, Denso, or NGK plugs in there. Bosch blows.
A can of Seafoam could help you out a little bit too.
DAMN!!!! I wish I would have know b4 I bought the damn things. I was thinking about going back to get Motorcraft plugs and slapping those in. The wires are new. I replaced those back in Jan. The autolites didn't seem any better.
