idle problem
Old Jul 21, 2008 | 12:23 PM
weightclass120's Avatar
weightclass120
Default idle problem
2000 v6 manual 100,000 mi, when im driving then put it in neutral the rpms drop to 500 and it bogs. but when i come to a stop they go back to 800. what could be the reason for dropping so low? thanks for any help
Old Jul 21, 2008 | 12:48 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Default RE: idle problem
Could be your MAF, or TB, could be the computer, or the Idle control modual going out. Does it throw any codes? Have you changed anything recently?
Matthew
Old Jul 21, 2008 | 01:25 PM
mcfarway's Avatar
mcfarway
Could also be IAC or vacuum ... is this only with the motor warm/driving? Need more details.
Old Jul 21, 2008 | 02:51 PM
3.8YOU's Avatar
3.8YOU
w/ 100,00 it could use a tune up if you have not already. but like matt said it could be your MAF. try cleaning it and then disconnect your positive and negative battery cables and touch and hold them together so it can try to relearn its idle.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
