replace flywheel
Old Aug 8, 2008 | 12:30 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: replace flywheel
ORIGINAL: Richbrad08
i heard aluminum not good for a dd car b/c the cluth will slip on a hill + i might plan on sc it need something a lil stronger
Uh, what do you think they run in drag cars. The flywheel has nothing to do with the friction surface when you buy a good one. The friction plate is removable and it's the same one in the aluminum one as the steel one.
Whoever told you that, no longer take their advice, for anything.
If you do drop the cash a lightweight flywheel, DO NOT do the lightweight pressure plate option, you'll reduce your rotational mass too much. Call Spec and tehy will balance your clutch/pressure plate and flywheel as a unit, makes it absolutely perfect.
Old Aug 8, 2008 | 06:33 AM
The Yellow Pinto
Guest
Posts: n/a
^^^ yeah, what he said. i had a alum. flywheel on my turbo cavi, and everyone was saying, ah, it is too easy to stall on the street, its tough to keep the revs up. im glad i didnt listen to what those idiots. it is an absolute blast to drive. its around the same lines as an underdirve pulley, or a lightweight crankshaft, or shorter gears, or shorter tires. youll love it.
Old Aug 8, 2008 | 10:10 AM
Richbrad08's Avatar
Richbrad08
well dame it comes in today got it from american muscle...isint lighter then the stock flywheel....the stel one weighs 22 lbs
Old Aug 8, 2008 | 08:58 PM
Phantoms's Avatar
Phantoms
ORIGINAL: RyansQuick6
jack car up
place on jack stands
unbolt driveshaft
remove inspection plate
disconnect clutch cable
use transmission jack to support tranny
unbolt tranny
lower tranny out of the way
remove pressure plate and clutch disc
unbolt flywheel
instal new flywheel to proper tq specs
instal new clutch and pressure plate using alignment tool
re-instal tranny
reconnect cluth cable
re-instal driveshaft
remove jack stands
lower car
done.
Exactly what the Haynes book would tell you to do.
5.0muscle
Jan 11, 2016 01:17 PM
9550
Oct 26, 2015 05:01 PM
67STANGX2
Sep 24, 2015 12:29 PM
MusicCity615
Sep 12, 2015 07:05 AM
Art161
Sep 9, 2015 10:33 AM
