windstar intake
Old Aug 16, 2008 | 08:12 AM
richmustang1880's Avatar
richmustang1880
Default windstar intake
it just came in yesterday. im not going to put it in for a couples weeks(leaving for vacation tonight). but i was wondering if any one had any tips for installing to make it go a little smoother.
Old Aug 16, 2008 | 10:50 AM
jthorn9's Avatar
jthorn9
The Godfather
While I can't give any direct advice for the install, I will say this. Make sure you have a digital camera with you for the install and take lots of pictures through out the swap, that way you know what goes back, and where. Also use tie wraps (colored) and use difference color combinations (such as green/green, green,orange/green,orange) so that you know what vacume and fuel lines go back where. That way between the pics and the color coding with the tie wraps, you can put everything back together quickly and properly.
Old Aug 16, 2008 | 11:42 AM
skitso's Avatar
skitso
excellent advice there jthorn
yeah i dont know about that im contemplating one myself
Old Aug 16, 2008 | 11:52 AM
Xemeth's Avatar
Xemeth
If you're doing the m112 you can't do the Windstar. One or the other type deal.
Old Aug 16, 2008 | 12:13 PM
mymustang44's Avatar
mymustang44
Just make sure you route he vacuum lines right. The only problem i had was keeping to iac lines from leaking. www.vapauto.com has a write-up of the entire install.
Old Aug 16, 2008 | 08:47 PM
richmustang1880
any plz help me i have everything in bolted down(with the exception of the vacum lines) but the throttle wont work it only opens about a 1/8" at full throttle tryed spacing the pedal about a 1/2" and no change help
Old Aug 18, 2008 | 02:44 AM
mymustang44
Get a 1/2" to 1" piece of 3/8(maybe smaller) fuel line. Cut it down the length of the hose and slide it over the throttle cable between the pedal and the cable and put zip ties around the hos.
Old Aug 23, 2008 | 11:21 AM
richmustang1880
ok well i spaceed the throttle cable and it helped a little but i cant get the throtle arm to rotate fully i mounted it to the coil pack mount exactly how it was on the stock set up(which is how it looks in the picture)
Old Aug 23, 2008 | 10:20 PM
richmustang1880
and its drivable but stil not perfect if someone could post some pics of thier throttle cable set up on the gas pedal and in the engine bay i would apreciate it alot
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
