its not a plate its a emblem glued to plexi glass custom cut to fiit that hole with blue leds
the backing is aluminum, not plexiglass. if it were plexiglass you would see behind the plate and you would be able to see all of the wiring and the mess from the stock radio harness. the back plate is a piece of aluminum cut to fit the hole then polished. the pony is a grill pony bought from ford that i made a "bracket" to hold it just slightly above the aluminum plate. in the middle of the aluminum plate there is a hole where i have a blue led mounted. this way it shines around behind the pony.
Originally Posted by sIx
Any write ups around here on how to wire that up to come on with the headlights? Or anyone willing to PM me some details? Would be Much Appreciated.
i dont know of any writeups.
i used the power from the automatic transmition indicator lights. these come on when the headlights come on and the led takes so little power that it does not effect them at all. if you have a manual the wiring is probably still there under the console, you just have to find it. if i remember right its a very small connector with a black and brown wire coming out of it. you have to take the center console out to get to it.
well thats exactly what i said to do. You can go to a place like ace that cut plexi, if they have scrap u will get it for free thats what i did. Also if you want the look of engraved rather than an emblem do what i said and put the sticker there. You can just attach the lights on to the remote wire.
i think smoked plexi a 4 inch neon with the emblem on it would look way sicker i hate anything chrome or billet are cars are mustangs not srappers on 22s. and if you guys were smart you would hook up the lights to the 12v accersorry plug because it only has power when key is on thats how i wired up my pillar guages in myy first sn95
That accually is a great idea to do the smoked out back.
you should have put the gauges like i did on the wire used to dim the radio.
