Engine block...
Old Nov 2, 2008 | 03:30 PM
D-Stang's Avatar
D-Stang
okay so from my understanding i should go with 99+ 4.2L f150 block .....i would also keep the crankshaft thats in the 4.2L and everything else (heads, cam, manifolds, pullys, oil pan.....etc. the basics) would be used from the 3.8L??
Old Nov 2, 2008 | 03:58 PM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
you would have to have an 01+ oil pan
Old Nov 2, 2008 | 04:08 PM
D-Stang's Avatar
D-Stang
ok so and 01+ mustang oil pan......soo evrything else will be fine or is there more that would need to be changed? and the transmission and computer will be fine im just think a good tune will need to be done?.......srry i have tons of question and if i do this project i want it done right the first time
Old Nov 2, 2008 | 08:19 PM
D-Stang's Avatar
D-Stang
i looked up some info on the swap....
is this accurate;
99-00 split port heads
- 4.2 shortblock or longblock
- You can use the 4.2 heads
- Mustang upper and lower intake and fuel rail
- Mustang 3.8 water pump
- Auto trans = 4.2 or 01-up flexplate
- 5spd = 01-up or rebalanced 3.8 (0 or neutral) flywheel and a pilot bearing
- V6 Mustang bellhousing
- Re-use your stock cam position sensor
- 01-up 3.8 oil pan
- 01-up 3.8 oil pick-up tube and screen
- 4.2 damper or 01-up 3.8 damper (use the 01 pulley for blower cars)
- Re-use the stock 3.8 oil pressure sender and tube
- Re-use the Mustang headers
- You can use the 4.2 or 3.8 dipstick. Just keep track of where 5 qts puts the mark when refilling with oil.
Old Nov 3, 2008 | 09:07 AM
LilRoush's Avatar
LilRoush
Correct. A MAJOR over looked part is the neutral flywheel. 99 and early 00 3.8L have externally weighted flywheels, and it translates to a vibration in the motor if you use the wrong one. (Speaking from first hand experience on this one..... my flywheels got switched by mistake on one of my swaps, and we fought the vibration for the LONGEST time trying to chase it down. Spent hundreds of $$ on sensors and I tore the motor down twice in the car looking for a bad piston, rod, valve, anything....)
Old Nov 3, 2008 | 09:58 AM
D-Stang's Avatar
D-Stang
well mines an automatic so therefore i dont need to worry about that......
Also i read that you can use the 4.2L heads, but can you use the 3.8L heads..which is perfered?
Old Nov 3, 2008 | 10:19 AM
LilRoush's Avatar
LilRoush
They are the same, lower intake is as well. The 4.2L upper intake is more similar to the Windstar intake, but a lot heavier and made of cast aluminum instead of composite. It' too big to use, so that is why most use the mustang upper intake.
Old Nov 3, 2008 | 10:34 AM
D-Stang's Avatar
D-Stang
okay thanks that helps, i was looking into maybe using the windstar intake neway.....im sure ill have more questions to come ounce i start this project.
this weekend i think im gunna hit up all the junkyards for the 99+ 4.2L hope i can find one lol
Old Nov 3, 2008 | 10:41 AM
sIx's Avatar
sIx
So the Mustang and F-150 heads are the same? So is the only real difference between the 3.8 and is the 4.2 the rotating assembly?
Old Nov 3, 2008 | 12:57 PM
D-Stang's Avatar
D-Stang
from my understanding and what ive heard YES..
ALSO!!!!! AM I BETTER OFF USING 01-04 MUSTANG PARTS RATHER THAN 2000??
