Engine block...
Old Nov 3, 2008 | 03:57 PM
  #21
l_shizzle_l's Avatar
l_shizzle_l
The cam is a little more aggressive in the stock 4.2 compared to the stock 3.8 cam.
It depends on which parts you are talking about. The 01+ 3.8 parts are better for the 4.2L swap for the most part though(excep the lower intake with the IMRC's).
You can also get a 97-99 4.2 FYI.
Old Nov 3, 2008 | 06:04 PM
  #22
D-Stang's Avatar
D-Stang
okay so ill get the 99-04 4.2L because i want the newest i can get....and ill get the block, crank and cam
ill use 01-04 mustang parts
what should i use for the lower intake thenn????
Old Nov 3, 2008 | 09:27 PM
  #23
l_shizzle_l
So you are going to keep the stock cam? If you are going to have the motor apart you might as well put in a better cam. The 01+ have IMRC's in the lower intake, which can be tricky to tune around. Your stock 2000 lower dosn't have them, so that would be ideal to use. I would also port that, the 4.2L's love to breath.
Old Nov 3, 2008 | 09:41 PM
  #24
D-Stang's Avatar
D-Stang
well i plan i getting the best in whatever i put on....i wanna build the motor to produce the most power and best performance....any suggestions on a cam? also im not pulling my motor and using parts from it im building accordingly buying new parts or machineng others.......what does ported mean i have some idea but not 100% sure
Old Nov 3, 2008 | 10:09 PM
  #25
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
i would say a 212/218 cam would do you just fine
Old Nov 3, 2008 | 10:13 PM
  #26
D-Stang's Avatar
D-Stang
where is a good place to get the parts from....i usaally get a lot of my parts from mustangs unlimted but thats just becuase im close to it. Also i really dont think they will have the parts neccassary to support what i need.
Old Nov 4, 2008 | 12:22 AM
  #27
l_shizzle_l
www.supersixmotorsports.com will have most everything you will need.
Ahhh. Ok, well now the question is are you building it for N/A(no turbo, supercharger, or nitrous) or F/I(turbo, supercharger or nitrous)? Are you wanting to run pump gas in the motor or race fuel?
Ported = porting = the widening of passageways so it can flow better and push more volume through.
Old Nov 4, 2008 | 03:57 PM
  #28
D-Stang's Avatar
D-Stang
i would be buliding it F/I....and i would want to use pump gass.......
Is it possible to just do a 5.0 swapp cuz my freind has a motor hes selling and he thinks it will workk??
Old Nov 4, 2008 | 05:12 PM
  #29
l_shizzle_l
I guess, I don't really know much about motor swaps.
Old Nov 4, 2008 | 08:57 PM
  #30
D-Stang's Avatar
D-Stang
yea nnever mind the 5.0 wont work.....thats a good website for the 4.2 parts i feel more confidant in doing this now knoing that that site has basically evrything
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
