ECT Sensor Help?
Old Nov 7, 2008 | 10:49 PM
sIx's Avatar
sIx
Default ECT Sensor Help?
I noticed that my car has had a little difficulty starting. Battery had a dead cell so I replaced it. But it still started strange and idled kind of rough. I had about 5,000 miles on some Bosh Platinums (crap) and they were soaked in gas.
I ran a scan, and it came back saying that the ECT was malfunctioning and it gave the symptoms of what I had noticed a while before.
Does anyone have any experience or ideas on this?
$.02 welcome
Old Nov 8, 2008 | 12:42 PM
Cryptostorm's Avatar
Cryptostorm
alternator?
Old Nov 8, 2008 | 12:46 PM
Cryptostorm
.. your ect is your temp sensor.. btw
Old Nov 8, 2008 | 04:51 PM
sIx's Avatar
sIx
So check the Alt? If its not that, about how much do one of those sensors cost?
Old Nov 9, 2008 | 12:28 AM
Cryptostorm
about 30 - 35 bucks... its located on your lower intake, might just need cleaned...
Old Nov 9, 2008 | 08:02 PM
red3.8_96stang's Avatar
red3.8_96stang
Post
Engine Coolant Temp sensor is a vital component to enable correct fuel air ratio control to the engine. It allows cold start enrichment & the ECU looks to the ECT to arrive at the correct fuel control depending on engine temp (amongst several other sensors). If this sensor is faulty it will affect how the engine starts & runs & also gas consumption. Very important sensor, if faulty get it replaced ASAP!
Old Nov 9, 2008 | 10:36 PM
sIx's Avatar
sIx
Thanks. I guess that would slightly explain my crappy gas mileage as of late.
Where on the lower intake? Well, if there are more than 1 sensor up there anyways...
Old Nov 10, 2008 | 08:09 AM
red3.8_96stang
You want the two wire sensor, the one wire sensor runs the temp gauge. I'll go take a look a bit later (car is my sons). The ECT looks very similar to the Air Charge Temp (ACT) sensor which is located on the air intake. So if you find a similar sensor screwed in the engine ,that'll be it.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
TfcCDR
Sep 14, 2015 12:08 PM
