4.2 v6
Old Nov 25, 2008 | 09:49 AM
MurderedStang's Avatar
MurderedStang
Default 4.2 v6
The 1997 F150 4.2 is a direct swap into a 00 3.8 correct? im interested in what parts i will need but i can most likely find a write up, im looking for what kind of power gains i could be expecting?
Old Nov 25, 2008 | 11:06 AM
l_shizzle_l's Avatar
l_shizzle_l
Not direct but close. you have to change your engine balance to internally balanced. Pick up a 4.2 shortblock and toss your mustang stuff on, tune it and call it a day. You could expect around 210hp/245tq
Old Nov 25, 2008 | 11:32 AM
MurderedStang
Not bad, thanks. the 4.2 is still a V6 correct?
Old Nov 25, 2008 | 01:50 PM
liqwidsilver's Avatar
liqwidsilver
Id say yes the 4.6 starts the v8's
Old Nov 25, 2008 | 04:09 PM
ezekiel90's Avatar
ezekiel90
it takes to mods better than our 3.8's right?
Old Nov 25, 2008 | 04:16 PM
l_shizzle_l
maybe slightly, it can flow a lot more air then out 3.8's though, so it would make since if it does.
OP you have to use a 01+ harmonic balancer, 01+ flywheel, and 01+ oil pan with the 4.2 shortblock, other than that you can reuse all of your mustang stuff(heads, intakes, cam(the stock 4.2 cam is slightly better than the stock 3.8 cam, so if it's in the shortblock go ahead and use it.)etc.)
Old Nov 26, 2008 | 06:43 AM
liqwidsilver
Would a 4.2 hook up wit a 1996 body style as well?
mustangguy96
Feb 3, 2008 01:36 AM
carman85
Jan 19, 2008 08:06 PM
03sixbanger
May 30, 2007 06:33 PM
FoRdBoY357
Apr 11, 2007 09:58 PM
98Ga
Jan 11, 2007 10:05 PM
