Red Foam on power steering cap help?
Old Dec 8, 2008 | 02:46 PM
Richbrad08's Avatar
Richbrad08
Default Red Foam on power steering cap help?
so i change my radiator fluid about to go on my power steering fluid and i noticed red foam? is that good? i goggle it and nothing.
Old Dec 8, 2008 | 04:54 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
The fluid IS red, so you jsut basically have bubbles. Do you have any leaks or anything?? I've never seen bubbles in my power steering fluid.
Old Dec 8, 2008 | 05:20 PM
Richbrad08's Avatar
Richbrad08
no my fluid is never low. i know the fluid should look like a reddish tint to it. so i drain it. then i got some Lucas power steering to stop the moan of it. and once it hit the resivor it just turn a bright pink. and the cap has a thick foam on it
Old Dec 8, 2008 | 08:06 PM
.boB's Avatar
.boB
It's from moisture in the system. When the fluid gets warm enough, the mositure will evaporate and end up on the underside of the cap. Not a big worry. Just keep wiping it off and eventually all the water will evaporate and it will quit doing that.
Old Dec 8, 2008 | 08:59 PM
Richbrad08's Avatar
Richbrad08
alright thks for the help
Old Dec 10, 2008 | 02:55 AM
cobra232's Avatar
cobra232
sorry nope. the car had Type F fluid put into the power steering unit. it is highly detergent. detergent by definition means foaming/scouring. dexron works better without the foaming. either is OK but the high detergent is what can cause some whining and alittle wear in the rack. the best is either dexron light red or straight powersteering fluid which is light yellow in color. type a or type F is deep red and real high detergent and heavier viscosity. Dexron in it's many forms are fine. dollar general powersteering fluid is best with alittle lucas added to it. it's low detergent but has the right properties.
in a pinch you can also use SAE30 oil mixed 50/50 with Kero for powersteering fluid or just 10W oil/hydraulic oil
Old Dec 10, 2008 | 11:29 AM
ooterman's Avatar
ooterman
When you say Lucas do you mean the salt stuff you eat? And By Kero you mean corn syrup? At what point did you think "Hey I wonder if this will work?" and toss that stuff in there?
Old Dec 10, 2008 | 02:43 PM
cobra232's Avatar
cobra232
no i meant lucas oil products and Kero i meant kerosene. we ran diesel mixed with 40W oil for heavy equip hydraulic oil in a pince before.
Old Dec 11, 2008 | 01:30 PM
ooterman's Avatar
ooterman
OKay, that sounds a lot better then tossing some candy and cooking stuff in your engine.
How you guys know that it would work? Just a quess or what?
Granatelli Sales
Mar 25, 2016 08:01 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
96stang3.8
Sep 10, 2015 06:42 AM
v8sn95
Sep 7, 2015 10:17 AM
