DPFE Sensor 2000 v6
Old Dec 22, 2008 | 12:58 PM
cruisr's Avatar
cruisr
Default DPFE Sensor 2000 v6
I'm throwing a P0401 code on my 2000 v6. I have had to replace the DPFE sensor in the past but I can not remember if it was this one or a 1996 v6 I had a couple of years ago. So first, the DPFE Sensor on my 2000 is the black plastic one. Were 2000s using the black plastic DPFE out of the factory or were they still using the aluminum potmetal ones? I do remember that the one I took of was aluminum.
Second, how exactly do I test this sensor? I have read to test with a volt meter, but not sure how.
Old Dec 22, 2008 | 02:42 PM
KillJoy's Avatar
KillJoy
The 2000's came with the aluminum one. Should be replaced with the black plastic one.
Old Dec 22, 2008 | 07:29 PM
l_shizzle_l's Avatar
l_shizzle_l
If you bought it from Autozone they should warranty it for like 4 years or something like that. I know the test for it is in your haynes.
Old Dec 22, 2008 | 09:47 PM
KillJoy's Avatar
KillJoy
Yeah, when mine went bad, I rented a Haynes from my local library and tested it. Thats how I found out mine was bad.
Old Dec 23, 2008 | 12:16 PM
cruisr's Avatar
cruisr
I found some Tomco Techtips that give a good explination. I'll run some test this evening.
Old Dec 25, 2008 | 08:07 PM
jrspony's Avatar
jrspony
Was there a recall on the old DPFE Sensor? Or was it just bound to go out and need replacing?
Old Mar 11, 2009 | 11:33 AM
BadgerJer's Avatar
BadgerJer
Default How difficult is it to get at?
I have a bad DPFE sensor (2000 3.8L V6). Where can I get a diagram so I can replace it? If it's the one I think it is (right on top near EGR valve), it should be a pretty easy replacement...
Old Mar 11, 2009 | 11:47 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
There wasn't a recall, the part was just modified. They usually go out in cold weather from water vapor getting inside and freezing, causing the circuit to break.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
