Swapping Fuel Injectors
take off vacume lines on upper intake, then remove the upper intake. then use screwdriver to remove C clips, then pull 'em out. undo what you did.
just look at what is needed to get to them. if somthings in the way, take it off or move it.
why do you need to?
it wont help HP any...
you'll need a retune if they're diff sizes.
and your stock ones are 21# which is good for about 250hp.
why do you need to?
One of the injectors has gone bad, since I'm swapping one out I might as well do all 6 since the vehicle has 185K on it....
Do you have a diagram on how to do it or where I can go to get a diagram? I work better with pictures and my Haynes manual doesn't help worth a crap.
its not really THAT bad.
just gotta make sure, the stuff u take off gets put back on.
a good way to learn is jump right in...forget the pictures.
I've swapped 'em 3-4 times.
key is to: either note which line/bolt goes where. then double and triple check lines/bolts.
now get to it!
now get to it!
why do you need to?
why do you need to?
Sep 16, 2015 07:53 PM
jaiidutch
Sep 14, 2015 10:29 AM
