Power Steering Pump problem?
Old Feb 21, 2009 | 12:54 PM
SuPa StaLLiOn 7's Avatar
SuPa StaLLiOn 7
Default Power Steering Pump problem?
So when I was at a red light last night, I was playing around with my steering wheel. It doesn't turn fully (the usual 2 1/2 revolutions). I was in my driveway in park and i tried just turning the wheel left like a quarter of the way, and it didnt budge. It felt like I was trying to turn the wheel while the car was off. I checked the power steering fluid and it was fine. However, I see some spots of dripped fluid on the ground right where the pump is. Is my steering pump done?
Old Feb 21, 2009 | 01:52 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
clean up both hoses really good, then have someone turn the wheel while the car is running. If you see fluid squirt, then it's the high pressure hose, if fluid just drips, then it's the return hose.
Old Feb 21, 2009 | 02:36 PM
SuPa StaLLiOn 7
Gotta check that out; just need someone to help me lol.
Old Feb 22, 2009 | 10:04 AM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
Lucas p/s fluid is good for finding small leaks and sealing them. I used it and it cured the problem. Now if you have a huge gash in your hose, dont expect that to work.
Old Feb 22, 2009 | 10:43 AM
RyansQuick6
Reverse Gear Member
yeah but if a hose is leaking it's probably due to age and deterioration, so it should be replaced.
jpplaw
Mar 19, 2025 08:53 AM
djbigskrilla
Sep 20, 2022 01:04 AM
Design1795
Jan 24, 2017 10:38 PM
eastexsteve
3.7L V6 Technical Discussions
Dec 4, 2015 05:41 AM
drumhedd2005
Aug 13, 2015 09:59 AM
