windows moduie wiring help!!
What im wanting to do is wire all 4 windows to a roll down/up module (which I own) but i want the trigger to be my convertible top switch so when i go to drop the roof all the windows lower in one smooth motion I also wanted to do it so that when the roof comes up and locks all the windows roll up with a separate module but i cant figure out anyway to trigger it at that point without a switch or something like that which i dont want..so ill just live with rolling them up manually ANYWAYS!! my question i wanna do all the taps to the kick panel wiring harness but a problem i cant find a simple diagram... that tells me which pin controls what... does anyone have a diagram?
PS i have a hayne book but it does show me exactly what im looking for..
You need to find an electronics professional to build you something. The ebrake has to be set or it has to be in park for the top to go down, and you need to make it to where the windows can go down without the top as well, it involves a few complex circuits and relay setups to work. Doesn't make much sense since you can push all 4 window buttons with one hand and the top with the other, since you have to be in park anyway.
i have the relay I just need to know where to make the connections and that was my intention to make it so they would only go down when the top going down (all together) i usually drop my roof at a stop sign or something so i just wanted to make it a quick as i can to no hold up traffic and it would look kinda neat with everything going down at once at the touch of a button
Also i can put my top down even in gear as long as the e-brake is up 1 click like i sayed its more just for ease of use 1 buttons does it all
jwog666
Dec 27, 2021 08:09 PM
