Cold air intake= decrease in fuel efficiency?
Old Apr 10, 2009 | 09:58 PM
mustang99v6's Avatar
mustang99v6
Default 1
Originally Posted by mustangman02232
try removing your right foot from the floor board
agreed! I know I stepped on mine quite a bit more when I got my CAI, so be aware. Also, you will lose quite a bit of MPG if you filled up with 10% ethanol gas. I've lost 50+ miles per tank due to ethanol. Now, I drive across town to fill up with the real stuff at fina.
Old Apr 10, 2009 | 10:38 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Get an actual plug, you probably have a leak where that bolt in plugging the hole
Old Apr 11, 2009 | 04:13 AM
blakstang04's Avatar
blakstang04
yea. i have a rubber stopper im sealing it shut with, along with some sealant. and goin bak in and retightening all clamps and just making sure everything fits snug..
but does neyone know that if there is a slow leak somewhere, if the engine light will come on or not? or does the engine light only come on if there is a prob with the sensors?
Old Apr 11, 2009 | 08:57 AM
jthorn9's Avatar
jthorn9
The Godfather
You'll hear a very high pitched whistling noise coming from the leak. You can also use two old tricks of either using a can of wd-40 or car cleaner and spraying light sprays around any suspected leak areas to see if they engine reacts, or you can spray soap water and look for the bubbles. Leaks behind the MAF are especially bad, so look for those first.
Old Apr 11, 2009 | 09:16 AM
moontang's Avatar
moontang
100 miles?! I'm lucky to get that I need a tune bad anyway to post on topic it has to be a leak
Old Apr 11, 2009 | 11:46 AM
RyansQuick6
Reverse Gear Member
I think you merely have a case of lead foot that usually comes from installing any performance parts lol
It happens to all of us.
Old Apr 11, 2009 | 01:04 PM
blakstang04
hm.. i just read this sealant CAUTION directions and it says to keep away from a motor or anything that sparks... Um, are all sealants flammable? Im guessing they are... but if theres one that isn't or something out there that is a good bonding agent for two rubber pieces. can someone tell me what that is? Even though this sealant is on the intake, and pretty far from sparks, and very little will be used, it still says to keep away from high heat.. so i really dont wanna take any chances. My intake gets pretty hot here in Arizona... Thanks.
Old Apr 11, 2009 | 04:01 PM
RyansQuick6
Reverse Gear Member
lol, black rtv might work
Old Apr 11, 2009 | 04:59 PM
blakstang04
thanks man. i was just thinking that. i dont know why i wasted money on this other sealant.
Old May 4, 2009 | 07:18 PM
mad_pony's Avatar
mad_pony
just loosen up the bolt the put silicone around it and tighten as long as its not so long that its blocking air flow
