Neg effect of using 91 oct???
Old Apr 27, 2009 | 01:02 AM
  #21
Zach333's Avatar
Zach333
Straight up attempt at a thread jack LOL
Try the s197 section
Old Apr 27, 2009 | 07:31 AM
  #22
bgnn32's Avatar
bgnn32
You won't see any negative effects using a higher octane, but you won't see any positive effects either.
Old Apr 27, 2009 | 12:02 PM
  #23
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Thats not true in my case...I saw positive effects with 91 in the fact that my horrible pinging went away with 91 opposed to 87 which is killing my car right now...
Matthew
Old Apr 27, 2009 | 01:55 PM
  #24
bgnn32's Avatar
bgnn32
Matthew
That is a band aid not a fix. The problem is still there you just can't hear it anymore, much like people who just turn up their radio so they won't hear a squeak.
Old Apr 27, 2009 | 03:13 PM
  #25
jthorn9's Avatar
jthorn9
The Godfather
Originally Posted by Biceps
Got a similar question if you guys don't mind. I have a 2008 V6 mustang. Any potential future problems with using 89 octane as opposed to 87?
No higher octane generally will not cause any issues, however most engines, more specifically, their ecus and timing/ignition systems, are programmed to burn 87, so running higher octane will not really yield any benefits unless either you're moded to the extent in which you need higher octane, or you have a problem and it can band aid it. Stay with 87 and save the extra dollars.
Old Apr 27, 2009 | 10:37 PM
  #26
Biceps's Avatar
Biceps
Thank you
guitarman376
Oct 11, 2015 01:47 AM
Widow Maker
Carolina Regional Chapter
Oct 3, 2015 07:06 AM
Drastang
Sep 30, 2015 03:48 AM
12bigredstang
Sep 24, 2015 10:43 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
