Overheating...
Old Jul 29, 2009 | 10:05 PM
Cadre!'s Avatar
Cadre!
Default Overheating...
Ok, so heres the deal. i have a 96 mustang 3.8 v6. About a month ago, i observed that my temperature gauge would begin to go slightly above the normal range when i drove in heavy traffic. the more i drove it the worse the problem got till the gauge almost reached the red range. If i cruise down the interstate, the car works perfectly fine and doesnt overheat. so i did some research, and read that i should flush my radiator and add some new coolant. so i did that and everything was cool for a couple of days. then all of a sudden my lower radiator hose bust, and i lost all of coolant and the car began overheating again...so i replaced the hose and put some more coolant in there. I was good for about another week, then all of a sudden tonight, the thing start to overheat again after i drove for thirty mins or so in stop and go traffic. What should i do next. i checked the radiator and im not low on coolant, so could it be the thermostat or should i quit being cheap and take it to a pro?
P.s. the cooling fan is operating properly as well
Old Jul 29, 2009 | 10:40 PM
cominus's Avatar
cominus
I would change the thermostat and do a flush, and if that doesn't work maybe a new radiator?
Old Jul 31, 2009 | 12:15 PM
rfcsoulja's Avatar
rfcsoulja
Is your fan comming on?
Old Aug 4, 2009 | 09:06 AM
Cadre!'s Avatar
Cadre!
Ok, well i think i solved the problem. turns out i had slow leak because i didnt tighten the clamps on my lower radiator hose enough. Next time ill use a ratchet instead of a screw driver. but thanks for yalls responses.
Old Aug 4, 2009 | 08:16 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
If your rad isnt low then its not a leak. Sound like you have a blockage somewhere. I would say get a flush to make sure you dont have anything blocking the coolent path.
Matthew
Old Aug 5, 2009 | 10:55 AM
jthorn9's Avatar
jthorn9
The Godfather
I would still make sure the fan is turning on/off or else it will continue to do that. Also, might want to look at that thermostat, they're dirt cheap and can fail at any time.
Old Aug 5, 2009 | 03:18 PM
rfcsoulja's Avatar
rfcsoulja
Let us know how it turns out.
Old Aug 5, 2009 | 08:57 PM
red3.8_96stang's Avatar
red3.8_96stang
Default Sticky thermostat?
Definately replace the thermostat. Whats your coolant (colour) like, is it bright green or gungy or rusty?
Old Aug 5, 2009 | 10:54 PM
Cadre!'s Avatar
Cadre!
thanks for posting yall. i really appreciate it. I found out i really was leaking fluid out of the radiator hose. i just didnt tighten the clamps on tight enogh so coolant was slowly dripping out. i also changed the thermostat for good measure. everything has been good so far. i'll post if any thing changes. yall can feel free to respond to my other post as well. it's titled stuttering.
Blown89houtex
Jul 17, 2010 09:41 PM
chaotic50
Jul 7, 2009 09:41 PM
chaotic50
Jul 3, 2009 12:50 PM
XLr8
Mar 16, 2007 06:08 PM
