What are these wheels?
Old Oct 1, 2009 | 11:15 PM
Azrael's Avatar
Azrael
Originally Posted by Fink
That hubcap isnt the kind that you need to remove the lug nuts first is it?
^^^Try that. I'll bet it may be the magical panacea for your dilemma. (Wow, it's obviously way too late...I just used words that confused me.)
Old Oct 4, 2009 | 05:05 PM
Mirage's Avatar
Mirage
I picked up a can of silver Dupli-Color wheel paint and some Dupli-Color Clear Coat for wheels and tested it on a brushed metal sawblade (thank god). It is a "bumpy" spray base coat that has a silver and white glitter effect in it. Looks very cheep. I used multiple light coats with the base and about 4 light coats with the clearcoat and ended up with a painted sawblade that looks like some 4 yr old used flat gray on then dunked it in silver glitter. Very dissapointed with the final product. Is there anything I can use to fix my wheels with? I dont have the money to either buy new wheels or have them sandblasted and start from scratch. I thought this was a simple job...
Old Oct 5, 2009 | 12:18 AM
Xemeth's Avatar
Xemeth
There still shouldn't be any grease if an axle seal went. Maybe a ball joint boot started leaking and the grease got out.
Anyway, I'm almost positive you don't have to loosen the lugs to get it off. Just take a screwdriver behind that little opening. It may feel like it's gonna break, but it shouldn't unless there's something wrong and it's stuck. Just stick a screwdriver behind it and work your way around.
Also, to clean them, just use some of that pink **** degreaser and spray it on there, then wipe off what you can, then spray it again and hose them off.
Old Oct 5, 2009 | 09:04 AM
Shaunmac9128's Avatar
Shaunmac9128
Yeah, sand them down get all that ****ty paint off and do it again, about your only option.
Old Oct 5, 2009 | 09:41 PM
TurtleSLow's Avatar
TurtleSLow
one of my center caps is cracked but it goes back on just fine, maybe yours is just stuck on there good, give it some oomph
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
