Loaded Cylinder
Old Oct 4, 2009 | 01:57 PM
jd694's Avatar
jd694
Default Loaded Cylinder
My 1994 with a 3.8 V6 is loading up the #2 cylinder with fuel,replaced the injector still the same. Any ideas?
Old Oct 4, 2009 | 02:18 PM
Bartro's Avatar
Bartro
Is that cylinder firing?
Old Oct 4, 2009 | 02:31 PM
jd694's Avatar
jd694
yes checked that
Old Oct 6, 2009 | 05:34 PM
neo8222's Avatar
neo8222
my friend had a problem like that... his ECU was fried and never turned off the injector
Old Oct 6, 2009 | 09:04 PM
Xemeth's Avatar
Xemeth
Take off the connector on the injector and put a test light on it with it running. It should pulse. If it stays lit the entire time, then it isn't getting turned off and it's probably an ECM issue.
Old Oct 8, 2009 | 06:13 PM
jd694's Avatar
jd694
yes the noid light stays on. Is there a way to tell if it is the ECM or the wiring?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
rgingo
Forum Issues and Feedback
Oct 21, 2015 12:49 PM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
b8checker
Sep 30, 2015 07:11 AM
