question.
Old Oct 14, 2009 | 04:05 PM
PKRFACE86's Avatar
PKRFACE86
Default question.
what grade of gas do you guys give your pony
Old Oct 14, 2009 | 04:09 PM
07 FltRoc GT's Avatar
07 FltRoc GT
Premium whenever possible.
Old Oct 14, 2009 | 04:23 PM
Xemeth's Avatar
Xemeth
Use 87 unless you have altered the spark timing enough to need 89-93. All octane is is a resistance to spark knock. If you use 93 octane on a stock tune, you're wasting 20-30 cents a gallon.
Old Oct 14, 2009 | 04:45 PM
Shaunmac9128's Avatar
Shaunmac9128
Our cars were tuned to run on 87 from the factory if I'm not mistaken.
Old Oct 14, 2009 | 04:51 PM
07 FltRoc GT
Yea i better check that out hu...probably best to use whatever the manual says for that reason. Do you think you would get any better production mpg wise from using a higher grade?
Old Oct 14, 2009 | 05:04 PM
PNYXPRESS's Avatar
PNYXPRESS
I use 89 octane in mine. Both have stock tunes and I noticed a increase in 2-3 mpg over an average of 20 tankfuls with the 89 over 87. I did not notice anymore gain running the 93 octane over the 89 though. Unknown of any power gain as neither car has been dynoed.
Old Oct 14, 2009 | 11:43 PM
PKRFACE86's Avatar
PKRFACE86
Cool thanks guys..I've been using 89 sometimes 93...the manual wants us to use 87
Old Oct 15, 2009 | 02:58 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Using a higher octane rating when it's not necessary is just wasting money. I run premium, but then again, I have to.
Old Oct 15, 2009 | 08:24 AM
moontang's Avatar
moontang
I run 89 but if I don't I get negative milage I do a lot of highway and that's where it helps
Old Oct 15, 2009 | 08:43 AM
PNYXPRESS's Avatar
PNYXPRESS
Does that mean your odometer runs backwards?
tmdm
May 2, 2021 02:49 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
mdj89
Aug 31, 2015 07:27 AM
toastintx64
Aug 29, 2015 05:12 PM
Hogquad
Aug 23, 2015 05:26 AM
