Cats
Old Oct 18, 2009 | 03:55 PM
  #21
Shaunmac9128's Avatar
Shaunmac9128
oh gt takeoffs, gotcha. I was hoping to get mine to the track before any new mods, but since it started snowing here today...idk. The nearest one is in NH, so I'm hoping for a warm friday so I can make a couple of passes.
Old Oct 18, 2009 | 04:06 PM
  #22
JUSTA6's Avatar
JUSTA6
im runnin a pretty stock car. mid pipe and clutch and tune. and with that im going an embarassing 16.0 at 90 mile an hour . i was running mid 15s b4 i took the cats off. hopefully this summer ill have the motor done and in the car and be running low 11s
Old Oct 18, 2009 | 04:11 PM
  #23
Shaunmac9128
damn 11's...after my 8.8 3.73's and intake spacer hoping for 16's maybee 15's. In the spring I'm going to get an udp, driveshaft, and hopefully some fresh rubber and by then I'm hoping to be in the 14's. Not sure where I'm going after that.
Old Oct 18, 2009 | 04:16 PM
  #24
JUSTA6's Avatar
JUSTA6
im building a nasty little blower motor. the motor im buliding is a 4.6L v6 thats runnin somewhere in the neighborhood of 10-1 i got a 4.2 crank that has been cut down to add .200'' to the stroke with 6.00'' scat H beam rods with custom forged ross pistons. i cant give the specs on the heads and cam cuz they are not done yet
Old Oct 18, 2009 | 09:12 PM
  #25
mustangman02232's Avatar
mustangman02232
Originally Posted by JUSTA6
im runnin a uncatted h pipe with faCTORY SHORTIES and a stock cat back and i lost about 20ftlbs and added .4 to my quarter mile times. you do need some back pressure and
ps. you should have cats. i have failed the md emissions 4 times
sounds like you need a driver mod, with a tune up/intake and LONG tubes with a full 2.5" cat back only i gained over a second and added 4 mph to my trap speed
what did you trap after you took the cats off? a 90 mph trap is good enough for high 14s with a good driver
Old Oct 18, 2009 | 10:08 PM
  #26
JUSTA6's Avatar
JUSTA6
im rollin throught the traps winding out third gear. and shifting at 5400. but i have been running the car on street tires and it has been spinning. ima try to get a good dry friday night and take its to the track before the end of the season with the DR,S on it and see if it makes a better pass
Old Oct 18, 2009 | 10:40 PM
  #27
Shaunmac9128
4.6 V6..damn.
Old Oct 18, 2009 | 11:04 PM
  #28
fordforlife0225's Avatar
fordforlife0225
mustangman why is it that you never have nething nice to say. my man tim seems like a good enough driver to run his car to its full potential. hey tim buddy, how bout comming to ford fever classic this weekend and letting me rent those tires off you for a pass or so?
Old Oct 18, 2009 | 11:08 PM
  #29
Shaunmac9128
He's actually very helpful, and has been to me.
Old Oct 19, 2009 | 12:37 AM
  #30
JUSTA6's Avatar
JUSTA6
i dunno if im gonna be able to make it down there i think im going to be going to look at a wrecked 04 cobra parts car. 4valve 6 speed and irs,and blower and in running order im told car has 27k on it
