Cats
Old Oct 17, 2009 | 03:54 PM
ll STANG ll's Avatar
ll STANG ll
Default Cats
what's up guys my engine is torn down in my 6 cylinder and i cut the cats out but im keeping them for the future when i sell it and what not. anyone have advice on how they sound or any problems with doing that? thanks guys
-mike
Old Oct 17, 2009 | 03:59 PM
neo8222's Avatar
neo8222
stock v6s need the back pressure of the cats cutting them out will lower the low end power of the car. You also have to retune with a handheld tuner or use MIL eliminators to make it run right, and it also gets much louder that rly about sums it up
Old Oct 17, 2009 | 04:04 PM
Shaunmac9128's Avatar
Shaunmac9128
can't your exhaust start to smell like shyt too.
Old Oct 17, 2009 | 05:10 PM
brent4's Avatar
brent4
x2 to what neo and shaun said. Also if when you get inspected and they give a visual inspection to see if cats are in place you could fail the inspection. Op have you looked into getting high flow cats?
Old Oct 17, 2009 | 06:38 PM
ll STANG ll
I actually know some one who had a 85 5.0 liter mustang with high flow cats..could i use them or no?
Old Oct 17, 2009 | 06:43 PM
Shaunmac9128
as long as they fit your size pipes sure.
Old Oct 17, 2009 | 06:53 PM
ll STANG ll
alright thanks alot guys..i'll post any other questions
Old Oct 17, 2009 | 11:38 PM
ayrton02's Avatar
ayrton02
Whatever low end power you lose will be made up for with a good tune. I wouldn't take them out unless you plan to do a full exhaust (longtubes, x or h pipe, chambered mufflers), otherwise it'll sound bad. Your exhaust won't smell bad... it'll just smell like exhaust Just don't put your nose behind the tailpipe like a dumbass and you should be able to tolerate it.
Old Oct 18, 2009 | 12:26 AM
fordforlife0225's Avatar
fordforlife0225
cats are like condoms. USE EM. you will fail emmisions and loose back pressure. rpmoutlet.com sells the pypes hi flow cats. i bought them and had a shop weld them into my mac h pipe.
the only was i dont think u could use hi flows is if u have long tube headers cuz there is not enough room in the h pipe
Old Oct 18, 2009 | 09:13 AM
Shaunmac9128
False. You need high flows with lt's to pass emissions. I've seen them welded to the mac h pipe before as well.
