Shift points
Old Nov 22, 2009 | 04:07 PM
Fink's Avatar
Fink
Default Shift points
I was fiddling around with the X3 the other day and I set the shifts points +5mph. I took it for a test drive and stomped on it and the car would get up and go from 0-20mph, then level out(accelerate slowly) then once it hit around 40mph it would downshift and take off again. This was all under WOT.
I plug in the X3 and set the shift points to 0 and test drive it again. The problem goes away. Accelerates hard and nearly breaks lose from 1-2. Shift firmness is set to 25%(highest).
What would cause the car to accelerate hard 0-20mph,accelerate slowly 20-40mph, then downshift and accelerate hard again? WOT was maintained the whole time.
Old Nov 22, 2009 | 06:30 PM
jthorn9's Avatar
jthorn9
The Godfather
Probably a programming conflict with the ECU. Don't mess with the stock shift points, they're nearly perfect on a 99-04, it's the 96-98s that can use some tinkering.
Old Nov 22, 2009 | 07:37 PM
Shaunmac9128's Avatar
Shaunmac9128
Can you just adjust the shift firmness with an X3? Helped with my diablo.
Old Nov 22, 2009 | 11:11 PM
Fink's Avatar
Fink
Yeah the shift firmness is at 25% (highest setting).
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
