I'm already running a 25% what does that plus the stock 112's upper pulley get you? around 11-13psi?
And sadly i'd end up using the SSM box (even though it's huge)
Might not be enough tall enough. All depends on how fast it rises. Some have used 4 inch cowls that don't clear the SSM adaptor plate. Depends on rise.
Small N/A cam
LT's
2.5" exhaust
Mysteed Performance M112 kit
dont forget his is a stick, auto cars will dyno lower
around 8psi
buy the full kit from nathan- comes with everything, and is shorter.
