m112 numbers
Old Feb 15, 2010 | 06:33 PM
dark knight25's Avatar
dark knight25
Default m112 numbers
hey guyz its rob once again would it be possible to post some numbers of ur car with the m112 on it and if its stock or not place you build if its not too much trouble im pretty sue theres alot of ppl who want to no different paths they can take in building there own sexy sixer thanks guyz
rob
Old Feb 15, 2010 | 07:16 PM
Richbrad08's Avatar
Richbrad08
v6power has more m112 then this forum. i'll post mine in about a month when i get all the parts in.
Old Feb 15, 2010 | 07:28 PM
karvounas's Avatar
karvounas
i'll gonna post mine too.
Old Feb 15, 2010 | 08:52 PM
Shaunmac9128's Avatar
Shaunmac9128
Yeah, check V6power.net for some serious M112 builds. Matt and Ryan can post theirs here, Matt no longer has the M112 to my knowledge but he was the first to do it (thanks Matt!) and Ryan (our mod) just did his not too long ago. Check the build threads over there for real info.
Old Feb 16, 2010 | 04:13 PM
LilRoush's Avatar
LilRoush
Depending on which boxed intake you use, expect your hp to be right around 300 @ wheels and tq to be a touch higher.
Old Feb 16, 2010 | 05:28 PM
JKs95stang's Avatar
JKs95stang
That's just stock tho' correct(LilRoush)?
Old Feb 16, 2010 | 05:33 PM
Shaunmac9128
It really depends on the tune and udp/blower pulley your running too, because of the psi. I have seen people make like 260wrhp and around or just under 300wrtq on a very conservative tune at 6psi I think it was. Other have pushed 300wrhp/tq through an otherwise stock car. Like Matt said, from the numbers I have seen generally its in the 290-310wrhp and 300-330wrtq range.
Old Feb 16, 2010 | 06:07 PM
LilRoush's Avatar
LilRoush
Correct, on an otherwise stock 3.8L car.
Old Feb 16, 2010 | 08:17 PM
mysteed's Avatar
mysteed
chaoticdismay- 330rwhp/300rwtq @ 8psi
Small N/A cam
LT's
2.5" exhaust
Mysteed Performance M112 kit
Old Feb 16, 2010 | 08:33 PM
Shaunmac9128
a 2.93 blower pulley and 42% (I believe not 25%) will net you 8psi.
