PLEASE HELP! overheating mystery!!
OK, so turning the heat on probably happened at about the time it was going to over heat like it did this last time without the heat being on. That would indicate lack of water flow or some type of restriction in the cooling system. It must of been very hard to install the water pump backwards. Did the Ford dealer install the thermostat? It might be up side down as they are mounted only one way. Does the radiator built up pressure on the upper hose when it is warmed up? Hang in there you can fix this, and good luck.
we don't think its the thermostat b/c it wasn't overheating until we installed the water pump - we got rid of the leak but then obtained the new problem.... still very confused. going to get it looked at again tomorrow and see what's going on; do you guys think the water pump is in wrong? we ordered the part from can tire and its prestone, specific to the year and everything, so i can't see it being the WRONG one.... thanks again guys.
mungodrums
Sep 29, 2015 09:18 PM
trashxtrash
Sep 20, 2015 10:49 PM
yourmom6990
Sep 14, 2015 10:52 PM
2001, 2005, 38, 99, cooling system, driving, ford, gt, heat, mustang, overhears, overheating, overheats, replaced, temperature, thermostat, v6
