Brakes Breaking?
Old Apr 3, 2010 | 11:56 AM
WoahPony's Avatar
WoahPony
Default Brakes Breaking?
I've never ever had this problem before so I'm confused. The brakes are super heavy and are really kind of hard to push in. Once I actually get the pedal to move it kind of idles in the pressed position for a second and the brakes remain applied. after a second or two it slowly starts to come back unlss I put my foot behind it and pull. What is this? if it was a fluid leak or something the pedal would be light, but like I said, it's super heavy
Old Apr 3, 2010 | 06:05 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Have you checked the fluid?
Old Apr 4, 2010 | 11:49 AM
compdude97's Avatar
compdude97
Check the fluid, if that is ok, then bleed the brakes, if that is OK then it is probably a master cylinder problem.
Old Apr 4, 2010 | 06:46 PM
WoahPony's Avatar
WoahPony
I'm gonna check the fluid tomorrow after school. One more thing, it only happens sometimes? sometimes when i start the car it brakes just fine, then other times it brakes like the fluid is semi-molten steel
Old Apr 4, 2010 | 07:01 PM
7 UP Mustang's Avatar
7 UP Mustang
If it has power brakes, check the vacuum hose from the brake booster over to the intake. Sounds like the rubber hose may be collapsing that provides the vacuum for the power booster. If so a new hose will fix it, other wise could be a booster problem. Good luck.
Old Apr 4, 2010 | 07:20 PM
WoahPony's Avatar
WoahPony
So, head to the local hardware store and pick up a length of vacuum line for a couple bucks, change the fluid, bleed the lines, and I'll be set. thanks guys haha.
jwog666
Dec 27, 2021 08:09 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
